When a network port is connected to a wire (segment/vertex) or edge port, a load can
be defined in series or across the terminals of a network.
Note: A network port refers to a port connected to a general network or transmission
line.
Load Placed in Series with Network
To place a load in series with the network, define the load on the wire
(segment/vertex) or edge port.Figure 1. The load is placed in series with the network.
Load Placed Across Network
To place the load across the network, define the load on the network port.
