Solving a Model with VEP
To solve a model with the volume equivalence principle (VEP), you must activate VEP for each relevant region.
- Select the region (or regions) in the 3D view or in the details tree that you want to solve with VEP.
- In the details tree, from the right-click context menu, select Properties.
- On the Modify Region dialog, click the Solution tab.
Under Solution method, from the drop-down list, select MoM/MLFMM with volume
equivalence principle (VEP).
Figure 1. The Modify Region dialog (Solution tab).
- Click OK to save the region properties and to close the dialog.
