Exporting an Animation
Export an animation of a model to use in a presentation or report.
On the 3D View
contextual tabs set, on the Animate tab, on the
Animation group, click the
Export animation icon.
Figure 1. The Export animation dialog.
From the Save as type drop-down list,
select one of the following:
- AVI
- MOV
- GIF
- MKV
From the Export quality
drop-down list, select one of the following:
- High
- Normal
- Low
Setting the quality affects the compression ratio for the specified screen size. For very high-quality exports, it is good practice to reduce the screen size to as small as is need and setting the Export quality to High. -
From the Export size
- Same as source
- QQVGA (160x120)
- QVGA (320x240)
- VGA (640x480)
- SVGA (800x600)
- XGA (1024x768)
- SXGA (1280x1024)
- Custom
In the Frame rate (frames per second) field, specify the
frame rate. Setting the frame rate affects how
smooth
the animation appears. -
Click OK.
The Animation export file name dialog is displayed.
- In the File name field, specify the name of the exported animation file.
- In the Save as type, specify the file type of the exported animation file.
- Click Save to export the animation to file and to close the dialog.
