Exporting Data
To export data, select the model, its configuration and the specific results to export to a native file format.
On the Home tab, in the
File group, click the
Export icon. From the drop-down list, select the file format to
export.
- In the Source panel, select the required configuration.
- In the Results panel, select a result for the selected configuration.
- Under Result options, specify the result-specific parameters.
- Click OK to close the dialog.
Specify a file name and click Save.
Figure 1. An example of the export dialog when exporting near field data.
