Storing a Local Copy of a Data Set
Stores a local copy of the underlying data that is represented by the trace. By storing a local copy, you can modify the existing model and compare the old results to the new results.
Select the trace that you want to store a copy of the underlying data.
Note: Most results from a graph can be stored, except for cable probes, error estimates, imported data, rays, and currents and charges.A new entry under Stored data is created that is accessible from the project browser or the ribbon.
Figure 1. Accessing stored data from the ribbon.
On the Trace tab, in the Manage group, click the
Store a copy icon.
