Assign a mesh generator to faces / volumes
To assign a mesh generator to faces / volumes:
Step | Action | |
1 | Activate the Assign mesh generator command (see next block) | |
→ | An assignment box is open. | |
2 |
Fill out the assignment box:
→ | The mesh generator is assigned to faces / volumes. | |
3 |
Go on assignment:
Quit the assignment sequence:
Activate the command
To activate the Assign mesh generator command, which requires data selection, choose one of the methods presented in the figure below:
Note: Reminder:
- To open a contextual menu, use the right button of the mouse.
- For multiple selections, keep the Ctrl key pressed.
