Propagate points / Propagate lines
Before starting
It is necessary to have a transformation (created beforehand) and points / lines to be able to propagate points / lines.
Propagate points / lignes
To propagate points / lines:
Step | Action |
1 |
Select the points / lines to propagate:
2 |
Activate the command *:
→ | A new dialogue box is opened. |
3 |
Fill out the fields:
4 |
Validate the information:
→ | The points / lines are created. |
→ | A new dialog box for the extrusion of entities of the same type is automatically opened. |
5 |
Quit the sequence:
Note: * You can also activate the propagation command by clicking on
in the menu (or on the icon
