3D curve: Display/Hide
Introduction
Once the 3D curve has been created, then it can be displayed on a sheet or hided.
Display a 3D curve
To display a 3D curve:
| Step | Action |
| 1 | Select in the Data tree the desired 3D curve |
| 2 | Activate the contextual menu by click right on the selected 3D curve |
| 3 | In the contextual menu click on Display |
| → | The corresponding sheet is displayed |
Note: it is possible to display several 3D curves, each sheet with its own tab that can be
activated or not, which permits to hide a 3D curve without hiding it.
Hide a 3D curve
To Hide a 3D curve:
| Step | Action |
| 3 | In the contextual menu click on Hide |
| → | The corresponding sheet is hided |
Note: It is equally possible to hide one 3D curve, starting from the corresponding tab
to its sheet by clicking on
