FIELD
Associates a material model to a field.
AcuSolve Command
FIELD ("name") {parameters...}
Qualifier
User-given name.
- material_model (string) [none]
- Name of a material_model entry.
This command specifies the material model associated with the given field. A
FIELD entry is required for all fields used in the
simulation, that is, those listed in the EQUATION::FIELDS
entry.
FIELD ( "water" ) {
material_model = "water model"
