getOeiValues()
Return the list of OEI integrated values.
Usage
oeiVals = adb.getOeiValues( name, var, unit = None )
- name (integer) or (string)
- Name or ID of an OEI name.
- var (integer) or (string)
- Name or ID of an OEI variable.
- unit (string)
- If unit is not None, the value will be converted to the new unit and be returned.
Return Value
- oeiVals (list)
- List of OEI integrated values.
This routine returns the list of OEI integrated values. This function needs two indices as
argument which are given by
name and
var. If
For
example,
trac = adb.getOeiValues( "wall", "traction", "N" )
