getPrbDesc()
Get the problem description and equations.
Usage
prbData = repAcs.getPrbDesc( )
None
Return Value
- prbData (list)
- Problem description info which is (mode, flow, temp, rad, spec, nSpecs, turb, mesh, ext).
None
This routine get the problem description and equations. For
example,
(mode,flow,temp,rad,spec,nSpecs,turb,mesh,ext) = repAcs.getPrbDesc( )
