udfGetOeiData()
Return data from an integrated element output set.
oeiData = udfGetOeiData( udfHd, setName, dataName ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- setName (string)
- Name of the ELEMENT_OUTPUT set.
- dataName (integer)
- Symbolic name of the requested data.
- UDF_OEI_VOLUME
- Total volume.
- UDF_OEI_VELOCITY
- Average velocity.
- UDF_OEI_ACCELERATION
- Average acceleration.
- UDF_OEI_PRESSURE
- Average pressure.
- UDF_OEI_TOTAL_PRESSURE
- Average total pressure.
- UDF_OEI_TEMPERATURE
- Average temperature.
- UDF_OEI_SPECIES
- Average species.
- UDF_OEI_EDDY_VISCOSITY
- Average turbulence eddy viscosity.
- UDF_OEI_KINETIC_ENERGY
- Average turbulence kinetic energy.
- UDF_OEI_EDDY_FREQUENCY
- Average turbulence eddy frequency.
- UDF_OEI_GRAD_VELOCITY
- Average gradient of velocity.
- UDF_OEI_GRAD_PRESSURE
- Average gradient of pressure.
- UDF_OEI_GRAD_TEMPERATURE
- Average gradient of temperature.
- UDF_OEI_GRAD_SPECIES
- Average gradient of species.
- UDF_OEI_STRESS
- Average Cauchy stress.
- UDF_OEI_HEAT_FLUX
- Average heat flux.
- UDF_OEI_SPECIES_FLUX
- Average species flux.
- UDF_OEI_MESH_DISPLACEMENT
- Average mesh displacement.
- UDF_OEI_MESH_VELOCITY
- Average mesh velocity.
- UDF_OEI_USER_OUTPUT
- User defined output.
Return Value
- oeiData (real)
- Pointer to one or two-dimensional real array of the requested data. The dimensions of the array
depend on dataName as follows. If the second (slower)
dimension is one, then the array may be treated as a one-dimensional array.
The x, y and z components of the gradient for gradient quantities are always
contained in the second dimension. The six components of the Cauchy stress
are, in order, xx, yy, zz, xy, yz and zx.
dataName First dimension UDF_OEI_VOLUME 1 UDF_OEI_VELOCITY 3 UDF_OEI_ACCELERATION 3 UDF_OEI_PRESSURE 1 UDF_OEI_TOTAL_PRESSURE 1 UDF_OEI_TEMPERATURE 1 UDF_OEI_SPECIES udfGetNumSpecs() UDF_OEI_EDDY_VISCOSITY 1 UDF_OEI_KINETIC_ENERGY 1 UDF_OEI_EDDY_FREQUENCY 1 UDF_OEI_GRAD_VELOCITY 3 UDF_OEI_GRAD_PRESSURE 1 UDF_OEI_GRAD_TEMPERATURE 1 UDF_OEI_GRAD_SPECIES udfGetNumSpecs() UDF_OEI_STRESS 6 UDF_OEI_HEAT_FLUX 3 UDF_OEI_SPECIES_FLUX udfGetNumSpecs() UDF_OEI_MESH_DISPLACEMENT 3 UDF_OEI_MESH_VELOCITY 3 UDF_OEI_USER_OUTPUT Determined by you
This routine returns data from an output element integrated set. For
example,
Real* oeiData ;
Real volume, ave_x_vel, ave_y_vel, ave_z_vel, spec_x, spec_y, spec_z ;
Real u_x, v_x, w_x, u_y, v_y, w_y, u_z, v_z, w_z ;
Integer specId, nSpecs ;
oeiData = udfGetOeiData( udfHd, "probe 1", UDF_OEI_VOLUME ) ;
volume = oeiData[0] ;
oeiData = udfGetOeiData( udfHd, "probe 1", UDF_OEI_VELOCITY ) ;
ave_x_vel = oeiData[0] ;
ave_y_vel = oeiData[1] ;
ave_z_vel = oeiData[2] ;
nSpecs = udfGetNumSpecs( udfHd ) ;
oeiData = udfGetOeiData( udfHd, "probe 1", UDF_OEI_GRAD_SPECIES )
for ( specId = 0 ; specId < nSpecs ; specId++ ) {
spec_x = oeiData[0*nSpecs+specId] ;
spec_y = oeiData[1*nSpecs+specId] ;
spec_z = oeiData[2*nSpecs+specId] ;
oeiData = udfGetOeiData( udfHd, "probe 1", UDF_OEI_GRAD_VELOCITY )
u_x = oeiData[0] ;
v_x = oeiData[1] ;
w_x = oeiData[2] ;
u_y = oeiData[3] ;
v_y = oeiData[4] ;
w_y = oeiData[5] ;
u_z = oeiData[6] ;
v_z = oeiData[7] ;
w_z = oeiData[8] ;
- This routine expects a valid udfHd.
- setName must be a valid name.
- dataName must be one of the values given above.
- The problem must contain the equation system corresponding to the parameter being requested. For example, the problem must contain a heat equation in order for UDF_OEI_HEAT_FLUX to be available.
