ufpGetType()
Return the type of the user-defined function.
type = ufpGetType ( ufpHd ) ;
AcuSolve User-Defined Function Basic Routine
- ufpHd (pointer)
 - The opaque handle which was passed to the user function.
Return Value
The type of the user-defined function is returned as an integer.
This routine returns the type of a user-defined function. There is currently no type
                                                  differentiation among AcuTrace user defined
                                                  functions; the function always returns a value of
                                                  1. This routine is reserved for future use. For
                                                  example,
Integer type ;
type = ufpGetType( ufpHd ) ;Errors
This routine expects a valid ufpHd as an argument; an invalid argument returns an error.
