ACU-T: 3310 Single Phase Nucleate Boiling
This tutorial provides instructions for modeling a single-phase nucleate boiling using HyperMesh CFD. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
The dimensions of the inlet are 0.03 x 0.04 m; the inlet velocity (v) is 0.39 m/s and the temperature (T) of the fluid entering the inlets is 368.15 K (95 C).
The preheated air enters the inlets and heat is transferred to the fluid from the walls. The heat causes sub-cooled boiling to occur in the region close to the wall and leads to formation of bubbles at nucleation sites.
The heat transfer in this regime is basically dominated by two effects, the macro convection due to the motion of the bulk liquid and the latent heat transport associated with the evaporation of the liquid micro-layer between the bubble and the heated wall.
The fluid in this problem is water, which has temperature dependent material properties: density, viscosity, enthalpy and conductivity. There are also surface tension and vapor phase models specified for this material.
Water vapor which also has temperature dependent material properties is specified as the vapor phase model.
The AcuSolve simulation will be set up to model steady state heat transfer to determine the temperature and heat flux on the heated walls of the manifold.
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T3310_NB1_Steiner.hm and click Open.
- Click .
Create a new directory named NB1 and navigate into this directory.
- Enter NB1_Steiner as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up Flow
Figure 4.
The Setup dialog opens. -
- Verify that Time marching is set to Steady.
- Select Spalart-Allmaras as the Turbulence model.
- Activate the Heat transfer checkbox.
- Click the Solve for boiling checkbox to activate Nucleate Boiling.
- Select Vapor_Therm for the Vapor phase model.
- Check that the Surface tension type is set to Constant and set the Surface tension value to 0.01.
Figure 5.
- Close the dialog and save the model.
Assign Material Properties
Figure 6.
- Select the model solid.
Select Water_Therm from the Material drop-down
menu.
Figure 7.
On the guide bar, click
to execute the command and exit the tool.
From the Flow ribbon, Profiled
tool group, click the Profiled Inlet tool.
Figure 8.
- Click on the inlet face, highlighted in the figure below.
In the microdialog, enter 0.39
for the Average velocity and 368.15 for the
Temperature.
Figure 9.
Click the Outlet tool.
Figure 10.
Select the face highlighted in the figure below, set the Static pressure to
200000, and activate the Back flow
conditions.
Figure 11.
In the Turbulence and Temperature tabs, set the back flow type to
Exiting Mass Flux Average
Figure 12.
Click the No Slip tool.
Figure 13.
Select the face highlighted in the figure below then click
on the guide bar.
Figure 14.
- Select the next face highlighted in the figure below.
In the microdialog, click the
Temperature tab, set the Thermal boundary condition
to Temperature and set the temperature value to
403.15.
Figure 15.
Click
on the guide bar.
- In the Boundaries legend, double-click on Wall 1 and rename it to Heated_Wall.
Double-click on Wall and rename it to
Bottom.
Figure 16.
Click
on the guide bar.
- Save the model.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 17.
In the Meshing Operations dialog, check that the Mesh
growth rate is set to 1.3.
Figure 18.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
- Save the model.
Run AcuSolve
Figure 19.
Expand Default initial conditions and enter the values
as shown below to define the initial conditions.
Figure 20.
Click Run to launch AcuSolve.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: While AcuSolve is running, right-click on the AcuSolve job in the Run Status dialog and select View Log File to monitor the solution process.
Post-Process the Results with HM-CFD Post
- Once the solution is completed, navigate to the Post ribbon.
Figure 21.
Select the AcuSolve log file in your problem
directory to load the results for post-processing.
The solid and all the surfaces are loaded in the Post Browser.
Figure 22.
- To check the temperature contours on the Heated_Wall and Bottom surfaces, right-click on those surfaces in the Post Browser and select Isolate.
In the Post Browser, right-click on
Heated_Wall and Bottom again
and select Edit.
A surface coloring microdialog opens.
Set the Display option to Temperature.
Figure 23.
Activate the Legend radio button then click
and set the legend properties as shown below.
Figure 24.
The temperature contours are displayed on the model.Figure 25.
Summary
In this tutorial, you successfully learned how to set up and solve a simulation involving a single-phase nucleate boiling using HyperMesh CFD. You started by opening the HyperMesh input file with the geometry and then defined the simulation parameters and flow boundary conditions. Once the solution was computed, you used HyperMesh CFD Post to create the contours of temperature.
