Files in ACUSIM.DIR
ACUSIM.DIR is the primary data storage directory for results from a
solution. ACUSIM.DIR contains various files that completely define the
simulation, including results. The directory stores data in a variety of files, each
corresponding to a different type of output. These files should not be managed manually.
Rather, if you need to manage the ACUSIM.DIR directory, see Manage Files in ACUSIM.DIR.
| File Grouping | File Extension | Description |
| Auxiliary Files | .slv | AcuPrep solver input |
| Basic | .cli | Replicated .echo file |
| .ddc | Domain decomposition | |
| .oqi | Mask information | |
| .top | Solutions summary | |
| .dat | Domain connectivity | |
| .osn | Surface composition | |
| Derived Quantity Output | .odq | |
| Nodal Output | .out | |
| Restart | .rst | |
| Time History | .oth |
