Launch a Simulation via Windows Terminal
Launch with CMD
Open a CMD window through either of the following methods:
- Double-click the
set_nFX_environment.bat
file. - Run
relative/or/absolute/path/to/set_nFX_environment.bat
in an already open CMD window to set solver paths.
Note: The shell window type changes to PowerShell (PS). - Double-click the
- Change to your case directory. Although it is possible to use absolute paths, it is recommended to use relative paths.
Run
nFX_SP -i case.cfg
Launch with PowerShell
Open a PowerShell window and run
relative/or/absolute/path/to/set_nFX_environment.ps1
.You may need to set your PowerShell execution policy to “Unrestricted” by typing one of the following commands before running the script:Set-ExecutionPolicy -ExecutionPolicy Unrestricted -Scope CurrentUser
This command allows for the execution of scripts for the current user permanently until changed. This may or may not be a security risk, depending on the user behavior.
Set-ExecutionPolicy -ExecutionPolicy Unrestricted -Scope Process
This command allows for temporary execution of scripts within the current PowerShell session. It has to be input for every new PowerShell window, if no other permanent method of setting execution policy has been used.
Run
nFX_SP -i case.cfg
nanoFluidX auxiliaries (nanoFluidX[c], nanoFluidX[p], nanoFluidX[m])
The script
set_nFX_environment.bat/.ps1
also sets the
environment for the nanoFluidX auxiliaries and they
can be run through nanoFluidX[c], nanoFluidX[p], and nanoFluidX[m] (no need for
.exe extension) and passing the relevant options. For example:nFXc --nfx nfxccase.cfg
nFXp -i case.cfg
nFXm -f PATH
Remember: Windows style paths with backslash “\” are not supported. This
is important when using nanoFluidX[c]. Use of relative paths
is encouraged.
