Set up a simple single phase gearbox for drive train oiling simulation using SimLab
for CFD-nanoFluidX solution. Oil distribution will be analyzed
and basics of the post-processing in SimLab will be demonstrated.
Note: A PDF version of this tutorial is available in the Model
Files section.
In this lesson you will learn how to:
Select Unit System
Import CAD Geometry
Define SPH Flow Solution
Define Oil properties
Define Initial Conditions
Define Body Force
Assign Motion
Create SPH Particles
Set Solver Settings
Set Result Request
Check Simulation Data
Perform Basic Post-processing in SimLab
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and nanoFluidX.
Model Files
Before you begin, copy the file(s) used in this tutorial to your
working directory.
