Inspire Family Unit Draw
A summary of the Altair Units (AUs) drawn by application.
The Inspire Family of applications provides integrated solutions for industrial design, rendering, concept design, design simulation, as well as manufacturing feasibility and process simulation.
First solver execution levels with the UI, second plus stacks AUs draw.
Application AUs License Feature(s) Description
Inspire Render 2 InspireRender Full-featured concept design rendering environment created specifically for industrial and product designers.
Inspire Studio 5 InspireStudio Full-featured concept design modelling environment created specifically for industrial and product designers.
Inspire 15 Inspire
InspireGeometry
Easy-to-use concept environment which empowers design engineers to leverage simulation and optimization throughout the design process. Including generative design, structural analysis, motion simulation, casting and stamping feasibility.
15 InspireOSSolver License feature is required when OptiStruct is used for structural analysis.
15 InspirePrint3D Set up model for Print3D.
It takes 30 AUs and check out InspireMfgSolver license feature to run Solver.
25 HyperStudy For Design Explorer integrated in Inspire.
30 Inspire Enables SimSolid as structural analysis solver.
30 InspireFluid Assess fluid and thermal behavior early for faster, more informed product design cycles.
30 InspireFluidsSolver Enables the InspireFluids solver to be launched. See Solver section.
30 InspireMfgSolver Full-featured additive manufacturing module with support generation/slicing, process simulation, for both SLM and Binder Sinter processes.
This feature is used to run the Print3D solver.
Sulis 15 Sulis A design for additive manufacturing tool enabling fast geometry creation for complex lattice structures and fluid flow channels.
Inspire Form 15 InspireForm
InspireGeometry
Invokes the Feasibility tab. A virtual environment stamping analysis based on part or tooling geometry. Thinning and formability issues, as well as estimated blank shape and maximize material utilization via blank fitting and nesting utilities can be evaluated. Forming feasibility via one-step solver.
30 InspireFormIncr Invokes the Tryout tab. A virtual environment stamping analysis based on part or tooling geometry. Thinning and formability issues, as well as estimated blank shape and maximize material utilization via blank fitting and nesting utilities can be evaluated. Forming feasibility via one-step solver. See Solver section.
15 InspireOSSolver License feature is required when OptiStruct is used for feasibility analysis.
30 InspireRadiossSolver Allows you to run incremental analysis using Radioss solver. See Solver section.
Inspire Cast 30 InspireCast
InspireGeometry (15 AUs)
InspireMfgSolver
A casting process simulation software that allows you to enhance and optimize their manufactured components with efficient mold design and process development.
Inspire Extrude Metal 30 InspireExtrude
InspireMfgSolver
Metal extrusion simulation solution.
15 InspireOSSolver License feature is required as OptiStruct is used for structural analysis.
Inspire Extrude Polymer 30 InspireExtrude
InspireMfgSolver
Polymer extrusion simulation solution.
Inspire Friction Stir Welding 30 InspireExtrude
InspireMfgSolver
Friction stir welding solution
Inspire Mold 30 InspireMold
InspireMfgSolver
Injection molding simulation
Inspire Resin Transfer Molding 30 InspireExtrude
InspireMfgSolver
Resin transfer molding simulation
Inspire PolyFoam 50 InspirePolyFoam
Polyurethane foam simulation. See Solver section.
100 InspirePolyFoamSolver
