Manufacturing Solutions
Unified environment for manufacturing process simulation, analysis, and design optimization.
HyperForm
HyperForm provides a unique finite element based sheet
metal forming simulation environment. It combines an extremely fast one-step and
incremental forming solution based on Altair
Radioss solver technology with the customized geometry
manipulation and mesh generation capabilities of Altair
HyperMesh. HyperForm's Die
Module takes a giant leap in bringing the product designer closer to manufacturing
by enabling engineers to create and analyze conceptual die designs in order to
generate an optimized die. Die concepts can then be read into any CAD system as a
starting block for the actual die build. The Blank Nesting tool allows manual or
automatic search for single or multiple blank configurations in order to maximize
material utilization. HyperForm can export data in
Altair H3D format allowing results to be visualized
using Altair
HyperView Player with any web browser. HyperForm 1Step
and incremental analyses are tightly integrated with HyperMorph and Altair
HyperStudy, which allows the optimization of forming
tools and process parameters using a highly automated approach.
- Benefits
- Introduces forming feasibility criteria early in product development, where the most significant improvements are possible
- Accurately predicts the blank size for improved material utilization
- Provides a powerful tool to modify and verify multiple process scenarios with the ability to record and reuse complex model setup for repeatability of best practices
- Visualizes wrinkles and splits, and fixes problems before cutting any steel
- Provides powerful geometric tools for designing binder and parametric addendum
- Provides an automated approach for optimization of stamping processes
- Minimizes material wastage via blank nesting
- Model setup for tailor welded blank and layered blanks
- New GUI to quickly set up optimization problems in sheet metal forming
- Springback positioner – Positions the part after springback relative to tools based on user preferences.
- Model setup for Hot stamping using LS-DYNA
- Drastically reduces the overall product cycle
For more information, reference the Manufacturing Solver help manual.
HyperXtrude
HyperXtrude User profile under Manufacturing Solver provides an easy to use interface for
HyperXtrude solvers for metal extrusion, polymer
processing, and metal rolling simulation. Refer to Solvers of this introduction for more details
about these solvers. All the sub-profiles under this user profile have the following benefits.
- Benefits
- Easy to use interface
- Meshing wizards for quick model setup
- HyperXtrude Job Manager to submit and manage local/remote jobs
- Built-in and expandable material database
- Process specific model setup tools
- Wizard for tool deflection analysis using Altair OptiStruct
Some of the key process customizations are listed below.
- Metal Extrusion
- Extrusion wizard for setting up for all problem classes supported by the solver
- Tools for bearing design and optimization
- Tube extrusion wizard
- Polymer Extrusion
- Wizard for extrusion using plate dies
- Coextrusion wizard to simulate coextruded parts with or without metal inserts and tool
- Interface to setup to runner balancing analysis
- Interface to setup a generic melt flow analysis
- Tire extrusion analysis wizard
- Easy to use interface for CFD tetrameshing
HyperMold
HyperMold provides a highly efficient and customized environment for the following
solvers:
- Moldex3D Solid
- Moldex3D Shell
- Moldflow (Midplane, Fusion, and Solid 3D)
- HyperXtrude for Resin Transfer Molding
Key features and benefits for each of these solvers are listed below.
- Moldex3D
- This user profile supports model setup for three dimensional injection
molding simulations using Moldex3D Solid solver.
- Benefits
- Easy to use meshing wizards for model creation
- Support for standard and fast cool analysis
- Model diagnostics (similar to the solver)
- Moldflow
- This user profile supports model setup for injection molding simulations
using Autodesk® Simulation Moldflow® software.
- Benefits
- Support for Midplane, Fusion (dual domain), and Flow3D analysis
- Easy to use wizards to setup models for all three model types
- Model diagnostics includes fusion mesh match estimator
- Tools to create runner system and cooling circuits
- RTM
- This user profile supports model setup for resin transfer molding
simulations using HyperXtrude solver for
RTM.
- Benefits
- Solid meshing wizard to mesh the model starting from solids
- Interface for material database to add, edit, and maintain material data
- Tools to create boundary and process conditions
HyperWeld
HyperWeld provides an efficient interface for setting up models and analyzing
friction stir welding with the Altair
HyperXtrude Solver.
- Benefits
- Easy to use wizard for setting up models for butt, edge, lap and T-joints
- Tools to create and setup models with complex pin shapes and other joints not supported by the wizard
Results Mapper
Altair Results Mapper is a tool that provides a framework
to initialize a structural model with results from a forming simulation. It is based
on the HyperCrash architecture.
- Benefits
- Incorporates the manufacturing effects into structural analysis
- Open environment that allows mapping of data between arbitrary solvers
Important: To access the tool, use a version of
Altair HyperWorks prior to version 2024.
