2024
Manage CAD, FE, and 2D parametric sketch geometry.
Clean up problematic areas on geometry.
View new features for HyperMesh CFD 2024.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Review geometric errors in the model's surfaces and solids and fix any defects.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Use the Defeature tool to automatically find, review, and defeature holes and other non-essential features.
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
Use the Validate tool to validate your entire model, review surface and solid checks, and fix any issues.
Use the Simplify Region tool to create simple shapes around selected geometry.
Work with discrete geometry like FE Geometry and floating elements.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
