2024
Prepare your model and run the simulation.
Prepare your model for a general AcuSolve simulation.
Define radiation conditions and create emissivity models.
Define thermal radiation conditions.
View new features for HyperMesh CFD 2024.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Set up the simulation model, materials, domains, and boundaries.
Use the Physics tool to turn on thermal radiation physics and define the thermal radiation settings used in the simulation.
Use the Surface Finish Library tool to create, delete, and import/export surface finish models. A surface finish definition is an ideal grey-surface emissivity model used in the radiation equation.
Use the Defaults tool to define global surface conditions for thermal radiation.
Use the Surface Finish tool to apply surface finish properties to selected surfaces.
Use the External tool to apply external radiation heat transfer to selected surfaces or thin solids.
Use the Opening tool to apply radiation boundary conditions at openings. A radiation opening definition provides a method of fully enclosing a fluid domain that is not surrounded by walls. This condition is appropriate for inlet and outlet type boundary surfaces.
Use the Output tool to apply radiation output settings to selected surfaces.
Define participating media radiation conditions.
Define solar radiation conditions.
Define direct, derived, and constrained mesh motion.
Define output conditions, run the simulation, and view the results.
AcuTrace is particle tracer that runs as a post-processor to AcuSolve.
Prepare your model for wind tunnel analysis using ultraFluidX.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
