2024
Automate simulation processes with templates and utility scripts.
Use python based automation to quickly setup HyperMesh CFD for ultraFluidX simulations in batch mode.
Documentation of HyperMesh CFD for ultraFluidX simulation case setup.
Create mesh refinement zones.
Get and set farfield mesh/element size.
View new features for HyperMesh CFD 2024.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Use the Template Manager to define rule-based logic for groups, geometric operations, and setup and automate simulation processes.
Use basic Inspire API to load data.
Create a wind tunnel.
Create a turbulence generator.
Identify parts.
Create a belt system.
Create a box refinement zone around a part. If no part is specified, a box is created around the entire model.
Create an offset refinement zone around a part. If no part is specified, a refinement zone is created for the entire model.
Assign a part as a custom refinement zone.
Define result output types.
Create a new fluid material.
Set output parameters.
Set simulation parameters.
The precursorRun script is a standalone command line utility that generates the .xml input files to run two simulations: a precursor ultraFluidX simulation with coarser mesh and fast turnaround time and a user desired ultraFluidX simulation starting from the results generated by the precursor simulation.
precursorRun
Post-processing utility that uses results from CFD simulations to generate a PowerPoint report containing images, animations, and graphs of the results from the simulation.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
vwt.getMeshSize() vwt.setMeshSize(value)
