Command Line Options
This topic summarizes the command line options that are supported by hwCFDReport.
Execute Commands
Command line utilities require zero or more options to run. These options may be supplied on the command line.
For example, to invoke hwCFDReport for problem with input file
aero.img, you can either issue the
command:
hwcfdReport --img aero.img
hwcfdReport.bat –img aero.img (Windows)To get the list of executable options along with their current values, issue the
command with the -h (or --help) option. This causes the executable to print a usage
message and exit. For example,
hwcfdReport --helpprints a
message such as the following and exits:MESSAGE:
Accepted Arguments:
help:
help
h
outputs all accepted arguments
input file:
input_file <file>
img <file>
this is a required argument
output directory:
run_directory <directory>
dir <directory>
if no directory is given, it will create output.dir in the current working directory
compare directory:
compare <directory>
if this is given, images in given directory will be used to generate a comparison pptx
report generation
rep <bool>
generate_report <bool>
determines whether report is generated or not. Defaults to true. Values passed are either "true" or "false"
animation
animation_format <string>
can be either mp4 or avi. Default is mp4
picture resolution:
res <string>
picture_resolution <string>
determines the resolution of picture file.
Defaults to "high".
value: "high" as high, 9000 x 6000
"medium" as medium, 6000 x 4000
"low" as low, 3000 x 2000
other
--delete : if given, all files in output directory are deleted. If not given and output directory is not empty, exit signal is given
Example use case:
hwcfdReport --input_file "../aero.img" --run_directory "../output.dir"
reads file aero.img in <local_directory>/
outputs to ../output.dir
output includes images and report PowerPoint, if generated
Commands
- help or h (boolean)
- If set, the program prints a usage message and exits. The usage message includes all available options, their current values, and the place where each option is set.
- input_file or inp (string)
- The input file name (file.inp) to be used in the templated report generation
- run_directory or dir (string)
- The location of the run directory
- compare (string)
- If this is given, images in given directory will be used to generate a comparison .pptx.
- rep or generate_report (boolean)
- Generate report containing images.
- animation_format (string)
- This option sets the format of the animation. Valid options are .mp4 and .avi. Default is .mp4.
- delete (boolean)
- If given, all files in output directory are deleted. If not given and output directory is not empty, exit signal is given.
