2024
Set up your model for analysis.
View new features for HyperLife 2024.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Use the fatigue tools to determine the type of fatigue analysis that the model will undergo.
Use the Material tool to associate predefined or user-generated materials with the model's parts and sets.
Use the Load Map tool to import/create multiple channels (load histories) which are then paired with subcases/loadsteps to create the fatigue events.
Run the model and view results.
Explore additional post-processing options related to the input result files.
