Delete Weld Lines
Remove weld lines from the model.
Delete weld lines in the following ways:
- From the HyperLife Model Browser, select a weld line and press Delete, or right-click and select Delete from the context menu.
- From the weld line browser, right-click on a weld line and select Delete from the context menu.
- In the Mark Weld dialog, select weld lines then click
