Create and Edit Parameters
Certain entities can be defined with parameters in the Entity Editor.
Create and Assign a New Parameter
Right-click on a parameter assignment field, or click
, then select Create from the context menu.
- In the Create Parameter dialog, define the new parameter by changing the Parameter Type and Parameter Value.
When you are finished defining the parameter, click
Close.
The Entity Editor creates and assigns the parameter to the selected entity.Note: These parameters can be used in HyperStudy for design exploration and optimization.
Edit a Parameter
, then select Edit from the context menu.
- In the Edit Parameter dialog, modify the parameter's data.
- When you are finished making changes, click Close.
Parameter References
Remove a Parameter
, then select Remove
The assigned parameter is removed from the selected attribute in the Entity Editor.
Select a Parameter
, then select Select from the context menu.
- From the Select Parameter dialog, select the parameter to assign an existing parameter to the selected attribute in the Entity Editor.
