Add a Sampling Fit Approach
Add approach to the study.
- In the Explorer, right-click and select Add from the context menu.
                In the Add dialog perform the following steps:
Tip:
        You can also add a Sampling Fit approach by highlighting specific runs in the Evaluate step (Evaluation Tasks and Evaluation Data tabs) or Post-Processing step (Summary tab) and clicking Verify.
