Define Model Dependencies
When defining a model, model resources identify additional files required for the model to evaluate successfully, for example reference files called by script or linked result files that were generated by other models.
$file, $filebase, and so
on. The proper syntax is ${varname}, for example
${m_1.file_2}.-
In the Define Models step, click Model Resources.
The Model Resources dialog opens.
- Optional:
Graphically view the model.
- In the Model Resources dialog, click Block View.
- Click and drag items to rearrange the view of the model.
- Use the options menu to determine which items display in the window.
- Select the model to which the resource will be assigned.
Click Add Resource and select the type of resource to
add.
- Add Input File adds a file that does not change.
- Add Output File tags a file that can be referenced by a link resource.
- Add Input Folder adds a folder that does not change.
- Add Output Folder tags a folder that can be referenced by a link resource.
- Add Link adds an Output File or Output Folder that changes with each run.
In the Select dialog, navigate to your working directory
and open the file/folder/resource to reference.
Tip: To correct mistakes, right-click the resource file and select Modify Resource from the context menu. The resource is maintained and the operation is performed on a new file.
In the Operation column, select an option.
- None leaves the file as is. The file is able to be referenced from its existing location.
- Copy copies the resource into the run directory.
- Move moves the resource into the run directory (this is only available for Link Resources).
- Copy Content copies all resources from the selected folder into the run directory.
- Move Content moves all resource from the selected folder into the run directory.
- Write Input is a special case for the resource file for the model (for example, the HyperMesh database for a HyperMesh model type).
- Click Close.
Tip:
- View Include files and links between models in the run directory by enabling Run Directory Preview.
- For guided help defining a model resource, click Resource Assistant.
