Select a Numerical Method
Select a numerical method to use when evaluating the Sampling Fit approach.
- In the Specifications step, Mode column, select a numerical method.
- Optional: In the Settings tab, change settings as needed.
Click Apply.
A run matrix is generated using the numerical method you selected.
