2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
Contains a pair of paths to batch mesh parameter and criteria files used by HM_ExtAPI::GenerateMesh.
Contains information about an individual component in the topology of mesh areas defined by the HM_Topology structure.
Contains information about an individual edge in the topology of mesh areas defined by the HM_Topology structure.
Contains information about an individual face in the topology of mesh areas defined by the HM_Topology structure.
Contains information about individual face loops in the topology of mesh areas defined by the HM_Topology structure.
Contains information that is used by the HM_ExtAPI::GenerateMesh() function to set meshing parameters in interactive and batch meshing modes.
Contains information that is used by the HM_ExtAPI::ImportModel() function to set import parameters.
Contains information that is used by the HM_ExtAPI::OffsetFaces() and HM_ExtAPI::OffsetShellsByFaces() functions to set offset parameters and return offset results.
Contains information about a point in three-dimensional space.
Contains information about the geometry of a line represented by approximation points.
Contains information about mesh area topologies that includes a set of faces, edges and vertices and topological relations between them.
Contains information about a transformation between different coordinate systems.
Contains information about an individual vertex in the topology of mesh areas defined by the HM_Topology structure.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
