This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
Command files can be used to create new command scripts that perform automation, or to recover previously performed steps.
HyperWorks entities are often used as string parameters in commands that act directly on entities in some fashion, such as creating filtered sets that contain only a specific entity type.
Marks specify groups of entities that are transferred to the command processor. Marks can be created for most entities, and commands are then issued to perform operations on the entities on the mark. HyperMesh allows for two standard marks and a user mark.
At times, it is necessary to define a vector or plane for a command. HyperMesh allocates two vectors and two planes with the IDs 1 and 2. The vectors and planes can be defined at any time during the processing of a command file or Tcl script.
Data names are used to access data from the HyperWorks database. A data name is a string that represents a piece of data. They are basically generic references to the information that physically defines an entity in the HyperWorks environment.
Tcl (Tool Command Language), commonly pronounced "tickle", is a scripting language like Perl, JavaScript, Born, and Korn. Scripting languages are easy to use and learn because they have a syntax that is easy to read, are platform independent, and do not require compiling.
The functionality of the HyperMesh Tcl Modify Command commands are available through Tcl. Additionally, commands that allow you to extract information from the HyperWorks database, such as entity ID numbers on a mark, a list of assemblies, component names, elements per component, nodes per element, node values, and so forth. These are known as HyperMesh Tcl Query Command commands. They are used to query information from the database or template system.
