2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
The HyperMesh Card Image panel is used to define solver specific data and review card information. The format of the cards and the menus in the panel are defined in the export template, using HyperMesh Card Preview Commands.
A template file is organized into blocks and when outputting a database, HyperMesh processes a template on a per-block basis. Blocks are output in the order that they are defined in the template file.
Template files allow you to access information from the HyperMesh database with two methods, data names and attributes.
Template files can also contain mathematical expressions.
Templates contain functions to test values, perform conditional statement execution, or control the template flow.
The HyperMesh Template Functions are available to query information in the database, perform mathematical functions, and query user-defined tables. A template function begins with the symbol @ and is followed by the variable arguments in parentheses. Template functions are always placed between square brackets [].
Card images are described by a template file block. You can display the card image using the card previewer.
This example demonstrates how to use template files to generate output files for nodes.
This example demonstrates how to use template files to generate output files for elements.
This example demonstrates how to use template files to generate output files for assemblies.
