2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Returns the background color that should be applied on a cell that passes this rule.
Returns a string containing a list of cell names that participate in this rule.
Returns the comparison operator used to compare the reference value with the actual value in the cell.
Returns the text color that should be applied on a cell that passes this rule.
Returns the reference value used to compare with the actual value in the cell to determine if the cell passes the rule.
Sets the background color that should be applied on a cell that passes this rule.
Sets the list of cell names on which this rule should act.
Sets the comparison operator used to compare the reference value with the actual value in the cell.
Sets the text color that should be applied on a cell that passes this rule.
Sets the reference value that is to be compared with the actual value in the cell to determine if the cell passes the rule.
Use the Task Manager to load an XML file that defines tasks and their attributes.
