2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the default background color.
Gets the default font handle.
Gets the default text color.
Sets the default background color.
Sets the default text color.
Use the Task Manager to load an XML file that defines tasks and their attributes.
