View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Projects a node to a plane along a vector.
Creates a vector from two points.
Calculates the angle between two vectors.
Calculates the cross product of two vectors.
Calculates the dot product of two vectors.
Calculates a vector defined by three points.
Calculates the magnitude of a vector.
Calculates the normalized cross product of two vectors.
Calculates the normalized dot product of two vectors.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
