2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
Reference to all MDL statements and blocks that can be used to model a mechanical system.
In MotionView, math or string functions can be used in property fields. These functions help in setting the value of the property that could range from simple arithmetic calculations to complex math equations. These functions also help in setting parametric relations to other properties.
MDL command set statements are used to create a solver command file when a solver input deck is exported from MotionView. A command set can contain MDL command set statements, Templex templates, or a combination of both. The commands in a command set are exported to the solver command file.
Provides a list of possible attachments for the corresponding *Attachment() statement in a *Define System() block.
Indicates the beginning of a form block inside a *DefineAnalysis() block.
Indicates the beginning of a panel definition block.
Creates a radio group.
Begins a selectable system block inside a system group for systems with attachments.
Creates a system group.
Begins a tabbed form block inside a *DefineAnalysis() block.
Begins a block for a selectable analysis task inside a task group.
Creates a task group.
Indicates the end of a form or tabbed form block inside a *DefineAnalysis() block.
Completes a preceding group block beginning with a *Begin() statement.
Identifies the end of a panel definition block.
Completes a preceding system block beginning with a *BeginSystem() statement.
Indicates the end of a tabbed form definition block.
Completes the preceding *BeginTask() block.
Creates a selection in a radio group.
Specifies instructional text for panel or form selections.
Adds a selectable system to a system group.
Adds a tab to a tabbed form.
Custom wizards allow you to define data processing wizards for use in MotionView sessions. Custom wizards can access data from, and output data to, files and curves in a session using data sets, templates, user-defined forms, curves, procedures and systems.
MDL variables, implicit entities, and Templex statements that can be used while creating an entity or expressions in MDL models.
Tires are critical elements to modeling a vehicle’s interaction with a road, with some tire models better suited to specific simulation domains.
Overview of the MDL Library reference guide.
