*physicalquantities()
Creates a physicalquantity in HMASCII format.
*physicalquantities (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the physicalquantity.
- name
- The name of the physicalquantity.
- color
- The color of the physicalquantity. Valid values are 1-64.
To create a physicalquantity with ID 100, name "my-entity", and color
1:
*physicalquantities(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021
