2024
Report APIs for Altair applications that use Tcl as a scripting language.
Add, access or modify report items.
Notifies all registered views to redraw itself.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Enables you to execute and export report.
Interact with items of type break.
Interact with items of type chapter. This item type is valid only for document reports.
Interact with items of type exceldocument.
Interact with items of type externalobject.
Interact with items of type image.
Create or modify report modules.
Interact with items of type property.
Interact with items of type slide. This item type is valid only for presentation reports.
Interact with items of type table.
Interact with items of type tableofreference.
Interact with items of type text.
Interact with items of type textdocument.
Interact with items of type worddocument.
For better performance data created, manipulated or deleted go into a cache.
Clone an Item.
Deletes the item with the specified ID.
Queries the value of one property or role or attribute.
Check if an item attribute, property or role exists.
Insert an item to a parent.
Check if the item is a leaf.
Check if the item with the specified ID is valid.
Load items properties defined in configuration xml.
Remove an item from parent.
Reparents an object that already has a parent.
Sets one or multiple parameters to specified values.
Evaluates registered validate callback.
Use the Task Manager to load an XML file that defines tasks and their attributes.
rpti::item redraw
