2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets an axis handle of a 3D plot client.
Gets a surface handle of a 3D plot client.
Gets a surface data handle of a 3D plot client.
Use the Task Manager to load an XML file that defines tasks and their attributes.
