Returns the path for the current working directory. If you switch directories in the
console or when loading files, the current working directory path will follow.
getcwd()
Input
N/A
Enter the following Templex statement in the Notes panel,
Text tab and click Apply:
{getcwd()}
The
current working directory, C:/Users, is displayed as the
note.
Figure 1. If you switch directories in the Console, the current working directory will
also change in the note if you click Apply in the Text
tab:
