Define Interface
Use the Define Interface tool to create, import, and edit geometric lines along the interfaces to evaluate.
These lines are required in the E-Line definition stage. Using the
Define Interface tool, you can:
- Create 3D lines
- Import geometry file
- Edit 3D lines
Create 3D Lines
Use the Define Interface tool to manually or automatically create 3D lines on the component edges.
From the SnRPre ribbon, Setup
group, select the Define Interfaces tool from the Define
Interface tool group.
Figure 1. -
Fast create geometric lines.
- Click
to create lines and remain in the tool.
- Click
to create lines and exit the tool.
- Click
to exit the tool without creating lines.
Geometric lines are created on the selected component edges. - Click
Manually create geometric lines.
- Click
to finalize the geometric line and continue creating lines.
- Click
to finalize the geometric line and exit the tool.
- Click
to exit the tool without finalizing the geometric line.
- Click
Import Geometry File
Import a geometry lines definition file.
group, select the Import Geometry tool from the Define
Figure 3. The Open Geometry File dialog opens. - Browse and select the required file and click Open.
Edit 3D Lines
Edit geometric lines. In the model, you can delete, combine, and split lines.
Delete Lines
Delete required lines from the model.
group, click the Review/Edit Interfaces tool from the
Define Interface tool group.
Figure 4. - From the guide bar, verify Delete is selected.
Click
to define the line length criteria.
Figure 5. -
Click Find.
Tip: If you created lines on all component edges, you can use the find functionality to delete all short lines. This can make line selection at the E-Line creation stage easier.All lines within the line length range are found.
- Optional:
In the modeling window, manually select the required
lines.
The number of lines selected to delete are displayed next to the Line button.
Complete one of the following options:
- Click
to delete the selected lines.
- Click
to delete the selected lines and exit the tool.
- Click
to exit the tool without deleting the selected lines.
This deletes the selected lines. - Click
Combine Lines
Combine two or more lines to form a continuous line.
Tip: The more accurate and well defined your
interfaces (geometrical lines) are, the less time you have to spend editing and
updating E-Lines at a later stage. Make sure you have one
Geometrical line per interface.
Figure 6. - From the guide bar, select Combine.
- In the modeling window, left-click to select lines to combine.
- Click
to combine lines and remain in the tool.
- Click
to combine lines and exit the tool.
- Click
to exit the tool without combining lines.
- Click
Split Lines
Split geometric lines.
Figure 7. -
Split.
The Split tool is activated from the Topology ribbon.
From the secondary ribbon, select the Lines tool.
Figure 8. - From the guide bar, select Lines from the Target selector.
- In the modeling window, select geometry.
- Optional:
On the guide bar, click
to define split options.
- Select the Trim intersecting lines check box.
- Click Split.
