Maximum Peak
Maximum peak is only available for studying modal contributions based on nodes as the selected pair.
From the SnRPost ribbon, select the
Sensitivity Analysis tool.
The SnR Sensitivity Analysis Browser opens. - Click Max. Peak.
Use the arrows to navigate in the plot to view the relative displacement peaks
and time of occurrence.
The plot highlights and labels the peaks values in relative displacement using horizontal and vertical dashed lines.
- Select a Top Contributor.
- Click Analyze.
