Assess the squeak and rattle risks by viewing the results from the squeak and rattle
analyses.
For risk assessment, you will need a result file from
analysis in OptiStruct containing relative displacement
output for all defined E-Lines.In risk assessment, the results from three types of events
are reviewed: dynamic, static, and thermal. Evaluation of rattle and squeak E-Lines are done separately.
