Jump to main content
HyperMesh NVH
HyperMesh NVH
2024
Index
  1. Home
  2. Full Vehicle NVH
    Access the Assemble, Analyze, NVH Tools, NVH Post, and Physics AI ribbons.
  3. Post-Processing and Diagnostics
    Define radiation conditions and create emissivity models.
  4. Load an NVH Utility
  • Welcome
  • What's New
    View new features for HyperMesh NVH 2024.
  • Get Started
  • Tutorials
    Discover NVH functionality with interactive tutorials.
  • Full Vehicle NVH
    • Assembly
    • Analysis
      Set up the simulation model, materials, domains and boundaries.
    • NVH Tools
    • Prepare Module
      Create, organize and manage the CAE parts.
    • Post-Processing and Diagnostics
      • Load an NVH Utility
      • Integrated Diagnostics
        Calculate a response, perform contribution analysis, plot results, and perform diagnostic studies and study response changes.
      • Modal Participation
        Plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
      • Grid Participation
        The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
      • Energy Distribution
        Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
      • Transfer Path Analysis
        Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
      • Design Sensitivity Analysis
        Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
      • Order Analysis
        Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
      • Modal FRF
        Calculate a frequency response based on modal results.
      • Model Correlation
        The Model Correlation utility determines the degree of similarity or correlation between two sets of results.
      • Radiated Sound
        The Equivalent Radiated Sound utility post-processes the results of exterior structure-borne radiated sound.
      • Global Modes
        Identifies global modes from an OptiStruct or Nastran modal analysis.
      • Flow Induced Noise/General Signal Processing
        The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes the results in both the time and frequency domain.
      • Green House Noise
        Post-process the pressure result of a vehicle panel obtained from ultraFluidX.
      • Mount Optimization
        Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
      • Optimization, RBDO
        Optimizes sensitive parameters for multiple sample analysis results using the RBDO or Deterministic approach.
      • Multiple Sample Analysis
        Post-process results from a Multiple Sample Analysis, including plotting a spread of responses (+/-95% and mean).
      • Deterministic Optimization
        Reads results from an OptiStruct optimization run and processes the results to review the overlay of the NVH responses, baseline versus optimized. Compare changes in the design variable values, baseline versus optimized.
      • Display Options
        Customize plots using the following options
      • Filter Contributors
        Filters contributors to a smaller set of data.
  • High Frequency NVH
    High frequency NVH is an implementation of Statistical Energy Analysis (SEA), and is used to predict and analyze the vibration and acoustic response of complex dynamic systems.
  • Squeak and Rattle
Load an NVH Utility
From the NVHPost ribbon, select an NVH utility tool to display the NVH-Utilities Browser and start using the tool. The NVH Utilities include:
ToolNVH Utility
Modal/Panel Participation
Grid Participation
Energy Distribution
Order Analysis
Modal FRF
Correlation
Radiated Sound
Global Modes
Mount Optimization
MSA Structures
MSA Loads
MSA RBDO
© 2024 Altair Engineering, Inc. All Rights Reserved.
