Create and Edit a Pipe
A pipe is a one-dimensional structural element with a constant cross-section that supports bending, torsional, longitudinal, and higher-order, cross-sectional deformation modes.
                From the Model ribbon, click the  tool.
                Create a pipe.
                Right-click on pipe to edit the subsystem and update the
                    parameters.
                Figure 6.
 Figure 7. Pipe Entity Editor
 - Name
- Specify unique name.
- ID
- Specify unique ID.
- Config
- Specify the element type.
- Property
- Specify the property parameter based on the element type.
- Damping
- Specify damping to the subsystem.
- Geometry
- Based on the element type, update the geometry parameters.
- Subsystem Options
- For experienced users, expand the Subsystem Options to change the default choices for the SEA Subsystems for all element types. For certain structural element types, use these options to adjust the default bending stiffness or conductance of the element and add non-structural mass, component mass, or fluid loading to the element when the options have been changed.
- Damping
- Assign a damping model to the element. From the Damping field
                                drop-down menu, select a damping model. This list contains all
                                predefined models which apply to the current element type. Click
                                     to display advanced damping options
                                that you can use to define additional damping models. to display advanced damping options
- Properties
- Assign a property model to the element. From the Property field
                                drop-down menu, select a property model. The element materials and
                                cross-sectional parameters defined in the selected Property record
                                are displayed. Property records can be used to simplify the model
                                definition in cases where many elements have the same properties.
                                Click  to display advanced property options
                                that you can use to define additional property models. to display advanced property options
                                that you can use to define additional property models.Figure 9.
 , and damping,
, and damping,  .
