- Activate
Command ElementSwitches on a formerly deactivated model element, and the modeling element can then be subsequently used in an analysis.
- Body: Flexible
Command ElementModifies a flexible body element.
- Body: Rigid
Command ElementModifies a rigid body element.
- Constraint: User
Command ElementModifies a Constraint_UserConstr element.
- Deactivate
Command ElementSwitches off a formerly activated model element. The modeling element is ignored in all subsequent analyses, unless it is explicitly "activated."
- DebugOutput
Command ElementThe DebugOutput command generates debugging output from MotionSolve. These extra diagnostics are typically used to understand MotionSolve analysis failures, so that modeling issues may be fixed and simulation parameters may be changed to get past the failure(s).
- Force: Beam
Command ElementModifies a beam element.
- Force: Bushing
Command ElementModifies a BUSHING force element.
- Force: Contact
Command ElementThe Force_Contact command can be used to modify the parameters of a Force_Contact model element.
- Force: Gravity
Command ElementModifies a gravity force element.
- Force: Joint Friction
Command ElementThe Force_JointFriction command can be used to modify the parameters of the model element.
- Force: Spring Damper
Command ElementModifies a spring-damper force element.
- Force: Two Body Scalar
Command ElementModifies a Force_Scalar_TwoBody force element.
- Force: Two Body Vector
Command ElementModifies a Force_Vector_TwoBody force element.
- H3D Output
Command ElementDefines an H3D output command.
- Load Model
Command ElementThe Load_Model command reads a MotionSolve XML file and builds a new multibody model.
- Load: Load Command
Command ElementThe Load_Command command reads the command block from a specified MotionSolve XML file and executes the command elements.
- Motion: Joint Based
Command ElementModifies a joint motion element.
- Motion: Marked Based
Command ElementModifies a marker motion element.
- Output: Results
Command ElementThe ResOutput command defines options for output files to be generated by MotionSolve.
- Parameters: Linear Solver
Command ElementModifies a linear parameter element.
- Parameters: Simulation
Command ElementModifies the simulation parameter element.
- Parameters: Static Solver
Command ElementDefines the solution control parameters for static and quasi-static analysis, where the parameters control the accuracy of the solution and the method to be used for solution.
- Parameters: Transient Solver
Command ElementParam_Transient defines the simulation control parameters for a time-domain-based nonlinear dynamic analysis.
- Post: Output Request
Command ElementModifies a Post_Request element.
- Reference: Array
Command ElementModifies an existing Reference_Array element.
- Reference: FrequencyInput
Command ElementModifies a Reference_FrequencyInput element.
- Reference: Marker
Command ElementModifies a marker element.
- Reference: Solver Variable
Command ElementModifies a variable element.
- Save
Command ElementThe Save command causes MotionSolve to write out the model data to a MotionSolve XML file.
- Sensor: Event
Command ElementModifies a Sensor_Event model element.
- Simulate
Command ElementPerforms a single simulation.
- Stop
Command ElementDefines a Stop command.
- User Defined Program Control
Command ElementDefines a UserProgramControl command.
