The design space for this problem consists of a rectangle with a single vertical load
at the free end. A circular cut-out is constrained in all translational
degrees-of-freedom on the inside free edge.
This is a compliance minimization problem with a material volume fraction constraint
of 20%. CQUAD4 (4-noded isoparametric) elements are used in a
design space defined by a rectangular region with an aspect ratio approximately
equal to one quarter of the short edge located closer to the edge away from the
load.
Subcase Section
The objective
function (compliance) is a subcase dependent response, therefore the response
reference is part of the subcase definition. The constraint (volume fraction) is
a global response, therefore the reference is outside the
subcase.
The responses and
constraints are defined in the Bulk Data section. Two responses are defined
here, the compliance (which is referenced by the objective function), and the
volume fraction, referenced by the constraint statement to put up an upper bound
of 0.2 (20% of the design space volume). The constraint statement is then
referenced as a global constraint in the subcase section.
BEGIN BULK
DRESP1,1,comp,COMP
DRESP1,2,volfrac,VOLFRAC
DCONSTR,2,2,,0.2
Figure 1. Finite Element Mesh of the Design Space for the Two-dimensional
Michell-truss
This example is analyzed using the one-file setup with the file,
michell.fem. The OptiStruct
batch job is submitted using the command shell script, % optistruct
michell.
Results
The optimization converges in 29 iterations. The results are requested in HyperMesh binary format and written to the file,
michell.res. The shape of the solution at the final
iteration is visualized by creating a contour plot of the density results at the
29th iteration in the HyperMeshContour panel.Figure 2. Contour Plot of Density Results for the Two-dimensional
Michell-truss
