New Keywords in 2024
Note: Please print this page for future reference.
New Starter Keywords
- /DAMP/VREL - To define the Rayleigh mass damping relative to the average velocity of the set of nodes or the motion of the local frame
- /FAIL/ORTHENERG - An orthotropic failure criterion based on fracture energy generating a stress softening.
Modified Starter Keywords
- /ANALY - Removed Isubcycle which is no longer supported
- /FAIL/BIQUAD - Added stress softening parameters, ICOUP, DCRIT and EXP
New Engine Keywords
- /SENS/RESET - Option to reset the sensor status at the beginning of the run
New LS-DYNA Keywords
- *CONTACT_ERODING_SURFACE_TO_SURFACE - Define surface to surface contact between a set of shell and solid elements
- *CONTROL_PARALLEL - Define parallel arithmetic option
- *ELEMENT_TSHELL - Defines 3-dimensional thick shell elements
- *EOS_GRUNEISEN - Defines a Gruneisen equation of state
- *MAT_030 (SHAPE_MEMORY) - Defines a super-elastic memory shape alloy material (SMA) compatible with integrated beam, solid and shell elements
- *MAT_154 (DESHPANDE_FLECK_FOAM) - Defines a material for modeling aluminum foam
- *MAT_187 (SAMP-1) - Defines a semi-analytical model for polymers material
- *MAT_252 (TOUGHENED_ADHESIVE_POLYMER) - A non-associated elasto-plastic model for polymer adhesives
- *SECTION_TSHELL - Defines the finite element properties of thick shell elements
Modified LS-DYNA Keywords
- *DATABASE - Added new options, GLSTAT_MASS_PROPERTIES and SPHOUT
- *ELEMENT_SHELL - Added new optional flag, BETA
- *MAT_003 (PLASTIC_KINEMATIC) - Added new flag, VP
