The Radioss solid tetrahedron element is a 4 node element with one
integration point and a linear shape function.
This element has no hourglass. But the drawbacks are the low convergence and the shear locking.
10-Node Solid Tetrahedron
The Radioss solid tetrahedron element is a 10 nodes element
with 4 integration points and a quadratic shape function as shown in Figure 1.Figure 1. (a) Isoparametric 10 Node Tetrahedron; (b) Nodal Mass Distribution
Introducing volume coordinates in an isoparametric frame:
The shape functions are expressed by:
Location of the 4 integration points is expressed by 1.
a
b
c
d
With,
and .
a, b, c, and d are the 4 integration points.
Advantages and Limitations
This element has various advantages:
No hourglass
Compatible with powerful mesh generators
Fast convergence
No shear locking.
But there are some drawbacks too:
Low time step
Not compatible with ALE formulation
Time Step
The time step for a regular tetrahedron is computed as:
Where, is the characteristic length of element depending on tetra
type. The different types are: Figure 2. Regular 4 Nodes Tetra
Figure 3. Regular 10 Nodes Tetra
For another regular tetra obtained by the assemblage of four hexa as shown in Figure 4, the characteristic length is:Figure 4. Other Regular Tetra
CPU Cost and
Time/Element/Cycle
The CPU cost is shown in Figure 5:Figure 5. CPU Cost in TEC
Example: Comparison
Below is a comparison of the 3 types of elements (8-nodes brick, 10-nodes tetra and
20-nodes brick). The results are shown in Figure 6 for a plastic strain contour.Figure 6. Comparison (plastic strain max = 60%)
1Hammet P.C., Marlowe O.P. and Stroud A.H., Numerical integration
over simplexes and cones, Math. Tables Aids Comp, 10, 130-7,
1956.
