In the modeling window, select which parts to include in the rigid group. Use
box selection to quickly select multiple parts.
Optional: Enter a name for the rigid group.
Click the + Create button on the microdialog, or click
the button on the guide bar.
Right-click and mouse through the check mark to exit, or double-right-click.
Tip:
You can view which parts belong to a rigid group using the Ground Parts
table.
To ungroup a rigid group, select the group using the arrow keys on the guide
bar and click the Ungroup button.
If a rigid group contains one ground part, the entire rigid group is
considered ground.
Joints, springs, or other connections between parts within a rigid group are
ignored for motion analysis.
You can also define a rigid group by right-clicking on an assembly or part
from the Model Browser and choosing Create Rigid
Group from the context menu. For assemblies, this method
will create a rigid group with the same name as the assembly.
When you copy and paste a part that belongs to a rigid group, make sure to
review your rigid groups. Copy and paste operations may alter your rigid
group definitions.
Rigid Groups Table
The Rigid Groups table allows you to review all of the rigid groups in your model and
their properties.
You can also view properties for rigid groups in the Property Editor by pressing
F3.
Figure 1. Rigid Groups Table
To
Do this
Display the group
Select the group name in the table.
Hide the group
Click the icon next to the group name in the table. Click again to show the
group. Alternatively, right-click a group name in the table and select Hide
selected from the context menu.
Rename the group
Right-click a group name in the table and select Rename
Show all groups
Right-click a group name in the table and select Show All
Groups from the context menu.
Ungroup parts
Right-click a group name in the table and select Ungroup
Shortcuts
To
Do this
Add part(s) to a rigid group
Toggle to the rigid group using the arrow keys on the guide bar, then hold down
the Ctrl key while selecting parts to be added.
Remove parts(s) from a rigid group
the Ctrl key while selecting the feature to remove.
Exit the tool
